Your stove is capable of burning almost 4 bags in 24 hrs, so the good news is your stove is not maxed out. It still has untapped capacity to heat more and hopefully meet your needs.Right around 2+ bags maybe up to 2.5 I would guess
200 pounds???? Do you mean since your last cleaning or since installation????I can clean it but only has had 200 lbs of pellets threw it.....
I took it to mean since installation. My MVAE took 2 or 3 days to get the first floor warm throughout. I haven't had it for too long, but the first few days I was wondering what was up with the poor output. I came home from work on the 3rd day and was all of a sudden very impressed, to the point of turning the oil heat off on the first floor. I'm playing with it now to try heating the upstairs well enough to turn that thermostat off as well.200 pounds???? Do you mean since your last cleaning or since installation????
Yea, 200 pounds should have been burned in the first two days trying to figure out how to run it! It's not panic mode yet.I took it to mean since installation. My MVAE took 2 or 3 days to get the first floor warm throughout. I haven't had it for too long, but the first few days I was wondering what was up with the poor output. I came home from work on the 3rd day and was all of a sudden very impressed, to the point of turning the oil heat off on the first floor. I'm playing with it now to try heating the upstairs well enough to turn that thermostat off as well.
If you have only burned 5 bags, give it a day or two more before you hit the panic button. There are a lot of cubic feet of air, especially with a chalet, to heat. As others have said, make sure your ceiling fan is in winter mode. Good luck and keep us up to date.
That's about $5x4 or $20 a day in pellets if you keep it blasting! OMG! Natural Gas where are you????Ahh, the square footage really means very little. Your heating space should be assessed in cubic feet, since stoves don't heat 2 dimensions. With that said, it appears that if you have only burned 200 lbs of pellets and you are cold it sounds like you are babying the stove. At full blast that stove will burn almost 4 bags (160lbs) in 24 hours.
It just occured to me that another possible reason for failure to heat is if the thermostat is too close to the stove. That would cause the stove to shut down when only the area nearest the stove is up to temperature.Ahh, the square footage really means very little. Your heating space should be assessed in cubic feet, since stoves don't heat 2 dimensions. With that said, it appears that if you have only burned 200 lbs of pellets and you are cold it sounds like you are babying the stove. At full blast that stove will burn almost 4 bags (160lbs) in 24 hours.
If the thermostat doesn't cycle as a result of proximity it won't matter. My thermostat is 3 feet from the stove. When I set it at 72 the space the stove is in is 70 with temperatures dropping a few degrees in all other locations.It just occured to me that another possible reason for failure to heat is if the thermostat is too close to the stove. That would cause the stove to shut down when only the area nearest the stove is up to temperature.
Heating a large space, the thermostat needs to be about half way between the stove and the farthest distance of that space. The area nearest the stove will run warmer than the thermostat setting unless you have substantial air movement. My stove keeps the area nearest itself at about 74 when the thermostat is at 70. The space furthest from the stove is at about 68.
Perhaps you are right, butIf the thermostat doesn't cycle as a result of proximity it won't matter. My thermostat is 3 feet from the stove. When I set it at 72 the space the stove is in is 70 with temperatures dropping a few degrees in all other locations.
The stove isn't a miracle worker and I'm afraid the OP was sold on the line "it will blow you out." It is just a space heater so perhaps we are trying to diagnose an expectation rather than a malfunctioning stove.
60,000 BTU/hr is a lot of heat capability. My oil fired boiler , that does the whole house plus DHW is only rated at just over 100,000. I can't help but expect that something isn't right.
Some people are online only once a daywonder why he has not came back?
Sad to say, not sure I could survive. I resisted for over 2 years before getting a smartphone. Now I can't seem to be without...Some people are online only once a day
The Original Poster of the thread. What does your flame look like? Jet engine or lazy like a low campfire?What is an OP?
