Wondeing if you have the Canadian Brand of Energex......Edit (running on no sleep) 520lbs of pellets and nothing to do with propane.... Sorry for the long confusing post also here are the 2 brands of pellets I have tried
this is mine in PA.
I get very good results from my ceiling fan in distributing the heat, but I run it on low.the fan is on med reverse and the loft is about the same temp.
You can't even look at it
It is not a slab full basment, tec is here now putting a 2013 blower he said the 14's are diffrent and now made in China not US any more? Also he had the computer hooked up to the thermostat.... I will keep you posted
This is odd, if you can burn a bag in 6 to 7 hours, that means you can burn almost 4 bags in a 24 hr period, which is about right for your stove, I believe. If it can burn that much, you should have plenty of heat, but you also said at the start of this thread that you burn 2 to 2.5 bags a day, and aren't getting much heat. If you can burn almost 4 bags a day, why are you burning only 2 to 2.5?I would guess it burns about 40 lbs in 6 to 7 hours, also am I doing some thing wrong my pellets have to be pushed over to the left towards the auger it's like the angle is not great Enugu or not smooth
