Mt Vernon not igniting
Greg Omagh
23
Central Mass
I have read a number of threads posted here over the years, but I can't seem to find one that matches my issue.
The stove igniter stopped working and, since I always carry a few spares, I replaced it. It still didn't work, so I did continuity and resistance tests and all passed.
I checked power at head of of the igniter and it was dead. The input just below was fine 120vac. The stove works fine when I manually start it.
I put a call in for service but they are weeks out (Central Mass here). Starting with the gel is a b///h.
Would appreciate it if anyone knows what the issue might be, or are we on new control board territory?
kappel15
2,599
Iowa
Define exact areas you are referring to, that do and don't have power. kap
Greg Omagh
23
Central Mass
The connector on the control board that the igniter harness plugs into has no power. The stove functions when the pellets are manually ignited.
kappel15
2,599
Iowa
Is the power cord connection, from the power supply brown, instead of white? The power cord eventually goes bad, and needs to be replaced when it starts turning brown. There is a fuse on the backside of the control board. kap
Greg Omagh
23
Central Mass
I have looked carefully at the wires and do not see any discoloration. Pic below.
Regarding the fuse, the place I bought from and who installed it said they "thought" that fuse would take down the whole stove. So I was left unsure about that.
kappel15
2,599
Iowa
Power harness looks good yet. This stove runs everything on dc power, except, the igniter. It is 120v ac. There are separate fuses for each. kap
Greg Omagh
23
Central Mass
I got a service date of December 27th. I would like to try to solve this myself. I assume the only way to replace that fuse to remove the whole board? It looks a like a squeeze in there.
kappel15
2,599
Iowa
Yes. You have to unplug all wires and remove board to get at fuse. Be careful as wires are delicate, as is connections. They do make a wire harness with inline fuses now, to avoid that issue. kap
rickwai
1,479
ohio
Worst design I have ever seen putting a fuse on the backside that requires board removal. Especially on an insert.....
kappel15
2,599
Iowa
Yep. Why i recommend the inline fuse harness, kap
Greg Omagh
23
Central Mass
I have two inline fuses on the igniter harness. Are you saying there's an option to get a harness from the power to the board with a fuse? Do we short the board fuse in that case, or hope the harness one pops first?
Thanks for your help, kap. I've ordered the fuses. We'll see if I can't make the situation any worse.
PS For anyone reading this later in the same situation. I gave up on the igniter gel and went for the butane torch. The igniter gel is a bit hit and miss.
kappel15
2,599
Iowa
No. I was talking about the igniter harness. They should of blown before the one on the back of the control board. kap
Greg Omagh
23
Central Mass
Hmmm. Well they didn't in my case. Now I am thinking I'll wait for the service call. My issue could be something else.
kappel15
2,599
Iowa
That's not to say, the fuse didn't blow on back of control board. If there is no power past control board, it points to that fuse. kap
