![[Hearth.com] My England Madison install [Hearth.com] My England Madison install](https://www.hearth.com/talk/data/attachments/216/216050-35eebcc950c890562cd2fea7a68ce749.jpg?hash=yqAtq-5FVI)
I always enjoyed your enthusiasm with cooking on your stove.
I also did Thai satay chicken roasted but didn't snap a pic. Originally the wife was going to use the glass top stove but I figured why not use the wood stove for that too lol. Because the heat isn't exact, it's important to keep an eye on things. The chicken ( breasts cut as strips and marinated ) only took 15 minutes baking and was perfect!
![[Hearth.com] My England Madison install [Hearth.com] My England Madison install](https://www.hearth.com/talk/data/attachments/216/216059-d41aa97296cfbc90f6f41bfcb9ccfdbc.jpg?hash=FSsim-99lJ)
I've done steaks and pizza in the stove before, I bought a cheap pizza stone from Home depot and used that, it did work great but was a pain to remove even with welding glovesAnd on the other end of things, I complain when anyone uses the woodstove as a temporary platform for putting their water bottle on the way out the door... (wife's notorious for that)
This is during the summer/fall of course. I don't want anything marking up the surface & prematurely rusting it :D
I really need to get into the foil campfire style cooking though. Never got the itch to try it.
Don't cook when you have massive amounts of fire or wood in it for one. I use a simple silicon glove and tongs. I set cooked things onto a bamboo cutting board. No issues at all lolI've done steaks and pizza in the stove before, I bought a cheap pizza stone from Home depot and used that, it did work great but was a pain to remove even with welding gloves
![[Hearth.com] My England Madison install [Hearth.com] My England Madison install](https://www.hearth.com/talk/data/attachments/216/216084-f8c370524c23fd9b4d51a1b0d3210a9b.jpg?hash=52hWck9CFx)
You are a renaissance man, Wayne Nestor!Don't cook when you have massive amounts of fire or wood in it for one. I use a simple silicon glove and tongs. I set cooked things onto a bamboo cutting board. No issues at all lol
I figure a half load at 7am gets me to about 11am. By then I have nice coals to cook on. Then repeat if I want to cook dinner in it. I only give it a good bit of wood overnight or if I'm leaving the house. ( Still roughly 3/4 full ). Still have plenty of coals for an easy light. Just toss a couple splits and some bigger stuff on top and she is good to go.
I clean ashes out every 2-3 days depending on how hard I'm pushing it. This is right now. Maybe about half packed and loose so I can clean the glass with a hot fire ( flue open and door slightly cracked right now ). Still looks as good today as when I installed.
I did notice a small gap around the door gasket but it's only a $15 fix from Amazon. If it gives me issues with air flow I'll fix it. For now it seems fine if I clamp the door completely shut. I bought high temp wood stove paint last season just in case, but haven't needed it yet.
So far the Madison is saving me about $250-300 US / month in the winter. Well worth the investment! Oh and I get most of my wood free too! View attachment 216053View attachment 216054View attachment 216055
Sent from my SM-N950U using Tapatalk
Those pics ( and 2-300 temps ) were from last year burning green green wood ( IE tree just cut ). The highest I'm getting now is 500-550 using an actual IR temp gun. Any hotter than that and my house it hitting 90 right now. The wood I'm using currently is 6-8 months seasoned. Was collecting all year. The reason I was burning green was it's all I had.6 months is nowhere close enough for the wood to be dry. 300 degrees is not hot enough to reduce creosote build up either. The stove should be in the area of 600+ degrees at optimal burn. Make sure you check your stack a few times over the season to make sure no heavy build up is going on.
Looks like the installer was kind enough to fix the gutters, that's always a plus. Enjoy
Wayne Nestor, you are intrepid.Those pics ( and 2-300 temps ) were from last year burning green green wood ( IE tree just cut ). The highest I'm getting now is 500-550 using an actual IR temp gun. Any hotter than that and my house it hitting 90 right now. The wood I'm using currently is 6-8 months seasoned. Was collecting all year. The reason I was burning green was it's all I had.
Also, I installed the stove and had a friend fix the gutter while I was at it. Not a fan of heights lol.
I completely cleaned the stack before burning this year. I bought a sooteater ( goes into a drill ) and used a cut milk jug to funnel the soot. FYI burning all green wood ( most burned the same week/ weeks it was cut ) created soot but it wasn't as bad as I thought it would be. Less than half a milk jug and the chimney was shiny metal again.
6-8 months seasoned made a HUGE difference in starting and maintaining the fire. Hardly ever need to add kindling unless it was like a 10 hour stretch loading wood. Also, I'm only loading 3/4 or less full. Even with only small embers, the wood I'm using now self catches if I leave the flue open and door slightly cracked. I've only had to make a new fire 1 time this season because we hit 60's for a few days and I let it die on purpose.
Aside from that, I've been sticking 1 - 6 to 8 inch thick split at a time during milder climate ( 40s to 50s ) for 2-4 hours and had no issues with black glass or the fire going out smoldering. I get 2 years seasoned is better.... But I'm not going to buy wood when I can get free wood. I'll just have to start even earlier next year before burning I suppose, and maybe try to stockpile an extra cord or 2 to start.
This is my first stove / fireplace since being a child ( 25-30 years ago ). Learning as I go and this is now my second season. Definitely improving though!
Lol yes you were. The minimum clearance on the sides is 18 inches ..... There's a big shield around the sides and back that decreases the needed clearance. Trust me, I've read read and reread the manual on clearances. I'm certainly clear of combustibles.Yes Wayne I'd say you've done well. I was on yah about your couch clearances in one of your threads I think? But it seems you're a conscientious burner, which goes a long ways for safety.
I always mention when people talk soot eater that it's important to always verify your whip is through to the top if cleaning bottom up. Visually, with binoculars if you aren't going up top. And nothing replaces giving the cap a good scraping off with a hand brush and visually inspecting the top of the chimney by accessing the roof.
8" and 6" will take two separate tools...the SE will work good on the 6" round...but it will do a poor job on anything square.no such thing as to much info, you will have people like me reading this stuff if they have been looking at buying a soot eater or madison.
ive been thinking about the eater not sure how good it would be on an 8inch square older masonry, also have a 6in round on my backup stove, purposly ade that one easy because of how hard the other one is. also goes basement to above second floor
I completely agree. It does an Excellent job on mine. I think you need the square brush that you drop down the chimney using a weight.8" and 6" will take two separate tools...the SE will work good on the 6" round...but it will do a poor job on anything square.
