Pretty much same here. The people that owned the house before me were nice folks, but they were a little over the top with security with all sorts of weird alarms systems and enough cable wire for three houses. I'm also removing the excessive cable wire from my utility room and a walk in closet that is directly above the utility room. There were at least 15. Now there are 2. One for each bedroom and downstairs there are 3, one for a bedroom, living room and family room. With the advances in wifi, the cable is still there for redundancy, but hopefully never needed again. I get much better speeds and connectivity with wifi. BBQ grill and a flat top grill for cooking. Battery powered lights. Some pretty cool ones that have magnetic bases and can be stuck anywhere. some that are motion sensors, too. And a couple of battery powered lamps that I use as well. I also have motion sensor solar lights at the important spots outside my back door and around the shed in case I'm out there at night and it helps me keep track of my dog.
I have a generator, the wood stove, several small electric plug in heaters and 3 power stations. I have a few panels for the one power station and at some point I plan to add a 51.2v 100a golf cart battery with a charger that can take generator power and clean it up and recharge the golf cart battery. I just got a small charge controller similar to the Victron 12-48v 100a though I won't go anywhere near those amps, more like 40 max. The battery will be connected to the 2kwh power station which has its own 2kw battery for a total of 9kw. I am also adding panels here and there to my shed roof. It will be able to hold about 2kw of panels. Then after that I will need to get creative with adding panels. My wife isn't crazy about ground panels. The ones on the shed roof she can't see don't bother her.
Since my solar project is temporary and experimental, I can't attach anything to permanent structures. The sheds are not considered permanent.
I'm thinking a pergola or something with a solar panel roof might be in order. You know... for my wife.
