I just joined today after reading up on Pellet Stoves for the last couple of months. GT Sharp, i just did the exact same as you, ordered the Castle Serenity from ACE using a 15% off coupon, they cancelled the order an hour later. I tried ordering it again with the code but it no longer worked! I found another code for 15% discount, ordered again and they havent cancelled yet!, fingers crossed. if all else fails i'll do the same and get it from HD.
. When you pick up at either Ace or HD be sure to check it over well. Mine was only attached to the pallet with 2 brackets which makes it pretty vulnerable, IMHO.
.I just joined today after reading up on Pellet Stoves for the last couple of months. GT Sharp, i just did the exact same as you, ordered the Castle Serenity from ACE using a 15% off coupon, they cancelled the order an hour later. I tried ordering it again with the code but it no longer worked! I found another code for 15% discount, ordered again and they havent cancelled yet!, fingers crossed. if all else fails i'll do the same and get it from HD.
let us know when you get your stove so we can initiate you into the Serenity sorority![]()
As i was looking inside after taking the side panel off i noticed the component on your picture GT_Sharp is the same as mine, there two of them, but the left one of yours is connected and the right one of mine is connected ?? is this some type of temp sensor and there's a spare one mounted in the fan outlet ? see pics blow:
(broken image removed)
. Haven't had any long burn times, just turn it on & off daily to take off the chill. I've chosen to dump the firepot before each start, it's way too easy
. Only burned less than 6 bags and still haven't dumped the ash pan. Less than a 1/4" accumulation in it
. I'm sure you're really going to enjoy yours!
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170719-2da3e0d96d7c406896fffc4f4df1634b.jpg?hash=Q4lfiBV4_l)
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170720-de6fbd591ec88c91cb02d19e4d3db941.jpg?hash=bmvRyi0J6G)
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170721-c2aef662a9cce71c35df47770f5de371.jpg?hash=XqR9yg3d5V)
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170722-245b17441b48194cba4bdcf4127d5b1b.jpg?hash=qomfIG-b4K)
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170723-e8d483952a20c533d5a6d1f40334d72f.jpg?hash=vdyYdORu3r)
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170724-f35d07b21c65ee11ed9e50f3fcec0b3a.jpg?hash=QWILHCWXw6)
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170725-485048d82de61e2146e59b2a1e193edd.jpg?hash=QGedymAgq6)
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170726-47b2731a782965b632af799fe9b0724d.jpg?hash=CKWZx0MY3y)
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170727-4f30b5b3376faec38d40e1591acd03d6.jpg?hash=EFjBhz9NTA)
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170728-69bdbda3a6c16e8004b1541eff89da0d.jpg?hash=cyP2wdAsAV)
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170729-7dc00fcf84dbb7f23a83ce546aecad9f.jpg?hash=-Km88lDjSg)
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170730-98f926a72a2b0973f60961087665ef55.jpg?hash=OWlIZVcBwk)
![[Hearth.com] My Journey with a Castle Serenity Pellet Stove. [Hearth.com] My Journey with a Castle Serenity Pellet Stove.](https://www.hearth.com/talk/data/attachments/170/170731-90b4b7deac97114cc436d2f7cf1a6d18.jpg?hash=Ug6kVgQS95)
Looks good.have you checked the air intake adjustment it sounds like it's open to far.
I've got the regular duravent thimble. Instructions said to make a 7x7 frame. As I've seen others describe cutting a round hole vs framing it out, I was curious as to how you did yours. Hope you love the stove. It seems like an excellent deal.
The Selkirk thimble I installed gave the same suggestion in their instructions. I interpreted it as being for stability if neededYehi just cut the hole out! Cant see what framing it out would do at all apart from giving you something to screw to !
. I did catch one stud on the right side though and I allowed some air between the thimble and the fiberglass insulation. Used wall anchors on the other side. I've done framing on the inside of walls in the past and it just turns into a cluster
This is a video of my Serenity burning on 1 at 'manual'. I consider it to be normal for me.
