GT_sharp, rich2500, this is what I got for air
http://www.amazon.com/gp/product/B0...st Pipe&qid=1446094581&ref_=sr_1_5&sr=8-5#Ask
at Amazon.
Should be just about right. If I can't make a 90 with it I'll add one. How about tape to seal stove and air/exhaust pipes where they slide on the rear stove ports? Have some aluminum heat tape but it doesn't seem like a real tight seal.
at Amazon.
).Pull the side panels and check all connections then leave the side panels off and put a good fuse in and run the diagnostic test if it's a component causing the short when the diagnostic test checks that component it should pop the fuse and that will tell you the problem.From what you have said so far it sounds like it may very well be the combustion blower
