Sure had a 15m probe when I was looking a while ago - but I don't think it had a connector on the end, just bare wires. You'd have to figure out how to wire to the guage - would be easy if you could find the right connector/plug likely.
Thanks mike,Here's what I ordered 3 weeks ago. They're not here yet. I got the same ones only blue this summer - got 6, have had two hooked up each with dual probes for a month or so. Didn't see the blue ones when I went looking 3 weeks ago, I think their offerings are in flux a bit.
(broken link removed to http://www.ebay.com/itm/Red-Digital-Thermometer-with-1pcs-DS18B20-Temp-Probes-/230844232854?ssPageName=ADME:L:OC:CA:3160)
How do you plan on getting the lead into the burn chamber?
ac
I think the only way, is to put the probe n the rear of the chamber and close the door on the wire. I assume since Rick has done it the wire doesn't get crushed and malfunction.
I will take some pictures tonight and post them later. I drilled and tapped a hole in the back door and put the probe from a pyrometer in the hole. That probe is aligned with the center gasification tunnel. I can get pyro readings in the 1800 degree range. the other probe is in a drilled and tapped hole in the ring on the top of the cyclone. That probe has readings in the 425 degree range. Pictures will help with understanding.
