For our new home, my wife wants a regular fireplace so she can open the doors ( if any ) to hear and see the fire unabated. I would rather have something like a high efficiency wood burning stove since I do the wood cutting and hauling. The best compromise appears to be a zero clearance, high efficiency fireplace such as the QuadraFire 7100, the Heat & Glo Northstar, or the BIS Tradition. However!!
I built several all masonry fireplaces in my younger days. We didn’t know any better back then. If I was had total control and was younger (O), I would build a Masonry Heater. Russian Style. I like their heat storage facet. So!!
I was wondering??? What would be ideal would be a naked Quad 7100, just the firebox with all its high efficiency works, baffle, air tight doors and etc. installed inside a masonry shell instead of that insulated sheet metal box. You still would have, actually have to have, the heat zone air system blowing through the masonry cavity. Not necessarily fan forced, gravity feed would work. I think it would actually be safer! OK!!
What do you think?? Am I missing something? How could such a unit be built? Do any manufacture offer a naked version? Not the old style Heatilator, they are just as bad as the old all masonry fireplace.
In the Q&A of this forum is one titled Best heating fireplace for new construction that says to build a masonry fireplace and install an insert into it. Are you kidding me
There has got to be a manfacturer that sees the market for new home fireplace construction?
Thanks,
Jim
There has got to be a manfacturer that sees the market for new home fireplace construction? Thanks,
Jim
