I currently have a 1,000 sq foot cabin (but adding additional space in basement soon) in North Georgia Mountains with a very very old Vermont Castings Defiant stove (pictures below). I am just in the process of getting the roof done so I figured, this would be the perfect time to move the wood stove about 10 feet to the exterior wall so it's not sitting in the middle of our living space... I called up a local company to come out and inspect the stove and give some advice and I honestly learned a lot considering I didn't know much about it.
It's gotta be around an 85' or older and missing key parts, basically, the thing is running on 'high' non-stop and uses an 8" pipe. Granted, I only use it for days it is below freezing (this year has been many) but it'll burn through like 12-15 logs in 10 hours keeping this house warm when the heat pump cannot keep up. So the company mentioned my pipes are rusting, very old and not great material / will be a safety hazard... basically to replace the pipes and move the current stove 10 feet it's going to be about $3,000 (was NOT expecting this much just for the current stove).
Now they tried to sell me on a Green Mountain 2019 model that supposedly burns up to 24 hours. But with that and the 6 inch pipe + install it's going to be about $5,000 (way way more than I was expecting). They recommend upgrading due to the age of my unit and not being able to find replacement parts.
So now my dilemma is what to do. I think it's probably worth it to find a budget unit that can heat the house and provide better burn times so I can actually use this thing around the clock next winter and not rely on heat pump at all. If I can get by using less than 10 logs a night, perfect! I'm assuming these newer units are going to really solve that issue?
I don't know much about this unit, perhaps someone here does? If a newer Englander or Drolet will outperform this for under $1,000 I don't see why it's not worth upgrading and trashing this one, but I am new to wood stoves.
Ideally, I wouldn't want to spend more than $3,000 for the entire new unit (pipes, install, hearth pad, etc.) so perhaps installing the pipe kit myself would be cheaper. But I realize I also need to prep the wall with concrete board and faux stone before I can install it all.
Mostly, this is one of many projects (this one I wasn't expecting to have to spend much on). We have a deck to replace, a wedding next February and roof starting soon... But once I get the roof replaced and take down this chimney, it has to be up before next winter or we may have some cold nights.
