I've been a long time lurker of this website and I've read countless hours on the type of install to have but I am just tired and on a dead-end on what I should do. Here's some info on my situation:
Now considering the 60 sq in area of the clay liner is less than their "AT MOST" recommendation, do I need to get a liner (thinking of draft) given the height of the chimney?
If I get a liner - will this in 5 x 7.5 = 37.5 sq in work? https://www.firesidechimneysupply.c...reflex-316ti-006-rectangle-chimney-liner.html - Will the 1/2" insulation still make this fit inside that 6" restriction? do I even need insulation? What about https://www.firesidechimneysupply.com/fireflex-316ti-006-oval-chimney-liner.html 5 x 7.4 with or without insulation?
Thank you for reading!
- Raised ranch / split level
- Live in Connecticut. Last year temperatures went down as low as -11 F, but average 10s/30s in Winter.
- Exterior Chimney about 24' in height.
- 6" x 10" ID clay liner = 60 sq in
- Bought Englander NC30 - 6" = 28.26 sq in area.
- Manual says liner must be at least # above, and AT MOST 2.5x # above = 70.65 sq in.
- Clay liner seems to be in good shape. I've been on the roof and inspected it (although I am not a professional, but it looks in good shape). Previous owners only used the fireplace a few times since 1969 when the house was built. the only thing I DID notice was a line going down one of the interior sides about 1.5 ft down from the top but that was all.
- Fireplace has damper about 6" opening, goes straight up, curves to the side around 45 deg angle, then straight up the remaining 20ish feet.
