Hello,
I've been reading this forum for a while, its filled with lots of useful information, thank you! First post here. First wood stove: just purchased a gently used 2yr old BK Ashford 30. We're located in the snowbelt region, north of Toronto. I'm planning to install the stove on the main floor of a 2 story building, on tile. Each floor is about 1000 sq ft, and are independent apartments with no connecting airflow. The main floor has an HRV with recirculate mode, which should assist in distributing heat. The plan is to use ICC double wall stove pipe & chimney running straight up, through the upstairs, attic and out the roof. We'll have about 20' of vertical stove pipe & chimney.
I have a few questions, it would be appreciated if anyone might have insight into these:
The previous owner of the stove said that the stove could be run with the bypass damper open, if one wanted a fire for visual purposes (i.e. nice flames). I've read on this site that than can cause issues if run like that for long times, but the manual indicates the stove should be run with the bypass open for a while during start up.
1) what damage do i need to look for, due to the previous burning with the damper open
2) the better half wants to have a nice fire to look at on occasion, under what conditions, time, temperature, etc. can the stove be run with the damper open, for visual reasons?
The tile on the floor is mortared to a thermal insulator (which is mortared to the slab) that doesn't provide the same support as tile on concrete. I'm a bit concerned with the point loads from the stove feet on the tile with this underlayment. Is there any suggestions of something I could use to spread the weight load from the feet over a bigger area? I guess steel plate might work.
Last question, I think, the model of the stove seems to be an Ashford 30, not the 30.1, however the Blaze King website only lists manuals for the Ashford 30 model. Is there any significant difference between the two models?
Thank you
Chris
Thank you
Chris
