Hi Everyone,
New user here, new home owner and a bit nervous. I am sorry if this has been explained, I just couldn't find answers that lined up with my wood insert and how it was installed/functioning. My wife and I just purchased a house and were excited to try the wood insert that came with the house, I used newspaper to start the flue and there was plenty of draw where it put out the flames from the paper. I put together some kindling and started the fire...once I opened the door (it is a single door) smoke started coming out the front. I kept it closed and let it heat up, even when I have the insert running hot, I cannot open the door all the way to rake the coals or to reload wood without smoke coming out the front. This is tough because I only have about 30% of an opening to work with if I need to move a log or put in more wood. I took off the flashing, removed the insulation and looked up the chimney, it seems like the pipe only goes up about 6-10 feet and the rest of it is masonry chimney. I have an external chimney and it is pretty tall. Its a drafty house so even when I opened a window, it did not correct the smoke spillage. Can anyone tell me if there is anything I can do to stop the smoke from coming in?
Thanks for reading,
Chris
Thanks for reading,
Chris
