And many others are below 1 gph.
We need to remember that the gph emissions rating of an appliance does not indicate the amount of visible smoke or odor it can or will produce.
I completely understand that.We need to remember that the gph emissions rating of an appliance does not indicate the amount of visible smoke or odor it can or will produce.
I understand and can also say that I’ve witnessed less smoke and odor from modern stoves ran well.I completely understand that.
Woodstock survival hybrid might work nicely in thereI understand and can also say that I’ve witnessed less smoke and odor from modern stoves ran well.
Below, my alcove. Tiles with air space behind. Been running safe for 20 years.
Do you know about the process of pyrolysis? Just because it worked this long without incident doesn't mean it will continue toI understand and can also say that I’ve witnessed less smoke and odor from modern stoves ran well.
I am an experienced wood burner
Tell us about your wood seasoning routine. It may need some changes for a newer stove.have very little experience with modern stoves.
That is almost it! My wife likes a bigger window…haWoodstock survival hybrid might work nicely in there
Split stacked and top covered.Tell us about your wood seasoning routine. It may need some changes for a newer stove.
Yes, I know about pyrolysis.Do you know about the process of pyrolysis? Just because it worked this long without incident doesn't mean it will continue to
It’s vented through the back with aluminum pipe pieces for spacers.Is the air gap behind the tiled surfaces ventilated, that is open at least 1" at the bottom and top so that air can circulate freely behind it? What was used for the air gap spacers?
I would not put a stove in there that does not have full side and rear shielding like the Kent does. Call Woodstock and ask what they think.Woodstock survival hybrid might work nicely in there
If the enclosure studs are metal and there are no combustibles involved, then it would be safe. If framed with wood studs, then it is less so.It’s vented through the back with aluminum pipe pieces for spacers.
it wouldn’t pass our local California codes ( neither would my house) but my stove has full sized bricks on the inside that keeps the sides from getting hot. I’ve done a few legal hearths. This isn’t one of them but i deem it safe.
I’m a builder and welder by trade. I have inteligente and good working sense.
My Kent only has rear shielding.I would not put a stove in there that does not have full side and rear shielding like the Kent does. Call Woodstock and ask what they think.
I thought the Sherwood had a metal side cabinet with an air gap from the actual stove body, similar to the PE Super. If so, that acts as a side shield.My Kent only has rear shielding.
No that’s maybe the tile fire you’re thinking of? The Sherwood is single wall 3/16”. Top has interior baffle. I bricked the insides and bed which raised the box temps and lowered side temps and smoke output.I thought the Sherwood had a metal side cabinet with an air gap from the actual stove body, similar to the PE Super. If so, that acts as a side shield.
Yes, must have been the Tile Fire. In that case, a stove like the PE Super or T5 or the Jotul F45 will be an improvement wrt reduced, side heat radiance. In cat stoves, the Regency 1500 and the BK Chinook and Ashford also have side cladding.No that’s maybe the tile fire you’re thinking of? The Sherwood is single wall 3/16”. Top has interior baffle. I bricked the insides and bed which raised the box temps and lowered side temps and smoke output.
Thanks Todd. The size is right.Look into the Jøtul F45, looks like it may fit your space.
The Regency has been on my list as a strong contender. I like the front controls and warranty.Yes, must have been the Tile Fire. In that case, a stove like the PE Super or T5 or the Jotul F45 will be an improvement wrt reduced, side heat radiance. In cat stoves, the Regency 1500 and the BK Chinook and Ashford also have side cladding.
We’re already good friends. I’ve done so much homework on the issue and talked it over with them as well.they’ve even offered to pitch in some $$. …good neighbors.I would invite my neighbor to the house and explain to him what you’re trying to do. Take him outside your home and explain the prevailing winds to him as well. Be sure and tell him your stove is older and that it’s your only heat source. Then tell him you’re planning to update your stove to a newer unit that is more efficient and modern in every way, be it a wood stove or a pellet stove. Tell him you’re making every change you can, but you can only do so much.
Compare emissions numbers from a wood stove big enough to heat your home. Do the same for a pellet stove. Even if their emissions numbers match...them look at the size of the exhaust and ask yourself which stove has the smaller exhaust. Which ever has the smallest exhaust means it’s breathing a lot less for the area being heated. At that point look at chimney height as well. It is highly doubtful raising your chimney will appease your neighbors. Now you looked at everything you can to change the situation. The rest is up to the weather and the burden of your neighbor. There is only so much you can do. A pellet stove may not be an option for whatever reason. Perhaps consider planting some fur trees along a property line to help break up the air flow going to your neighbors. That may just help as much as anything.
The problem is prevailing winds and a swale behind their house that creates an odd turbulence that make the smoke drop to their porch instead of just drifting by overhead.
i love my exisiting stove, and after all of my “research” it seems that a new 2021 cat stove would be cleanest replacement and I’m willing accept the possibility, more efficient with wood. I burn all night so the cat once again makes the most sense.
The problem is the price and finding the right fit for my space.
yes, cat stoves burn a little cleaner on an overall average burn cycle but during start ups and reloading you need to bypass for 15-30 min until the cat is up to temp and you will see quite a bit of smoke, more so than a non cat. Maybe the hybrid stoves have eliminated this bypass smoke, jury is still out?We’re already good friends. I’ve done so much homework on the issue and talked it over with them as well.they’ve even offered to pitch in some $$. …good neighbors.
