New member here, just got a BK Princess 29 Insert on Tuesday. This one replaced a 93? Country Comfort 350cc left by the previous owner. I think the final measurement of the chimney was 25.2 from base of hearth to the top of the original liner, final ss liner was around 22.5 after an elbow was used.
I started slow with firing it up to do a little breaking in and on Wednesday decided to load it up with 4 pieces of oak and activate the cat after it got warmed up. Things went well, but then it started to blow past the active range on the temp probe, even after I turned the thermostat down. I've seen the other posts where it is mentioned, I've had a similar issue with it going past the white zone on the probe and around to the 6 o'clock position. I turned it down to low and things recovered, but it stays in the top 3/4 of the active zone. I then turned it up to the 3rd dot and it again went past the active zone, but managed to stay at the edge of the active zone just over the 2nd dot. I did all of this slowly to let it settle out and avoid rapid changes. I also avoided throwing the bypass to vent the heat as I didn't want to warp the plate or crack the cat.
Contacted my installer and he came back out to seal up the elbow and connection to the new flue liner. So I started again tonight after doing a cure on the furnace cement and ran into similar issues, though not as bad, above the 4th dot it seems to climb above the active zone. I know the probe isn't great for actual temps past the "you can activate the cat now", but it remains concerning with how it wants to run past the active zone. One thing I did notice was the bypass lever needed to be pressed down very hard, more than the installer indicated when running through operation. I think that was part of the problem on the first attempt. It has now made a distinct "click" where before it went from "easy to move" to "clear resistance" and then "easy to move" again, where I thought it was properly seated. Flames were in the back and my glass got very dirty. Now that I pushed it down really hard to where it clicked, flames are all around the sides and back like my old unit. Also the cat isn't burning nearly as bright nonstop, so I'm less concerned overall, but it still seems odd it gets so hot on the low settings. What are people normally running the thermostat at? I know it's not freezing temps, so I'm testing it out in the 40s and 50s here (F).
One final question for installation, unfortunately I don't have a picture right now. My installer cemented the "flue trim ring" (mentioned in another thread) about an inch above the actual stove onto the elbow stating that it is only used for keeping debris from falling into the unit. Is that right...? The installation instructions don't really cover it as I've tried to find a proper install picture. From lurking on the forums it seems to me that the flue trim ring actually stops the air from escaping when the blower is on so that it is directed to the front of the unit. The reason it is a separate piece is so it can be properly sealed to the unit and then tightened to the elbow or liner once in place. If someone has a properly installed picture, that might help. I don't want to overstep the expert and fix it myself, so I'd need to convince him. (also installation warranty...I don't want to do any modifications on my own until the unit is properly working and tested)
I'm really looking forward to having this unit working as it should. Even with the issues, it stayed in the active zone for 12+ hours with a half load which is many times more than my older country comfort. Maybe one day I'll even get the final pieces of trim that the factory didn't include and a non dented shroud top. I already love the stove, I'd just like to get through these initial installation pains so I can really enjoy it.
![[Hearth.com] New Princess 29 Insert - Questions - Running Very Hot & Installation [Hearth.com] New Princess 29 Insert - Questions - Running Very Hot & Installation](https://www.hearth.com/talk/data/attachments/294/294049-b0086f424eaaa22447318bb140c13ab1.jpg?hash=4_EtolHDhE)
![[Hearth.com] New Princess 29 Insert - Questions - Running Very Hot & Installation [Hearth.com] New Princess 29 Insert - Questions - Running Very Hot & Installation](https://www.hearth.com/talk/data/attachments/294/294050-c00736b2b8473702e3ae68d15aed80f0.jpg?hash=EKv3MROqq0)
![[Hearth.com] New Princess 29 Insert - Questions - Running Very Hot & Installation [Hearth.com] New Princess 29 Insert - Questions - Running Very Hot & Installation](https://www.hearth.com/talk/data/attachments/294/294057-5b3e7fae633e67473c34638c9e617c3a.jpg?hash=CVaTbDOLWz)
![[Hearth.com] New Princess 29 Insert - Questions - Running Very Hot & Installation [Hearth.com] New Princess 29 Insert - Questions - Running Very Hot & Installation](https://www.hearth.com/talk/data/attachments/294/294081-fd32f614aac38d2926fa8a073ba02063.jpg?hash=KOZroXyfpa)
![[Hearth.com] New Princess 29 Insert - Questions - Running Very Hot & Installation [Hearth.com] New Princess 29 Insert - Questions - Running Very Hot & Installation](https://www.hearth.com/talk/data/attachments/294/294082-1208393b0b9cf4a1f1a2b81083e15189.jpg?hash=S7qtYSH-JM)
