New to the Forum - Crown Royal 7400MP
We sorta Derailed Mike's thread LOL,
My life is one giant tangent so no worries 😂
[Hearth.com] New to the Forum - Crown Royal 7400MP
I’m planning on building a drone trailer with one of these scissor lifts being the loft platform for an elevated operators platform.
Mother Nature decided to be hot and dry this fall when we needed it most and bottled it all up for one day. 1.75” of rain in about 20min here yesterday.
You know it was dry because less than 24hrs after a 2” rain and I’m back in the field picking up bales. This greed stuff is oats I seeded with the drone. I can’t believe how nice it looks !!
First load of soybeans bales headed home. 20 done, 325 bean bales to go and around 1600 corn straw bales to haul. See you in awhile lol. The neighbor took off already with his loads. It goes pretty quick when we fill them up. I can haul 22-24 on my trailers and he’ll take 36 on his two trailers. We figure around 60/trip so 35 trips and we’ll be done or around 4 days to haul just over 2,000 bales off the fields.
Pretty @jblnut, been a bit gloomy here the last few days, did get the boiler and all hooked u, fired up around 1400 saturday, with a fresh load of water in the boiler and storage at atmospheric temp, got here all up to temp about 1730 last night, only running DHW right now but it wont be long I'm sure
Reactions: jblnut
Was gonna burn some sawmill slats yesterday after I milled some slabs for a guy to make a bar top but the electric motor that runs the hydraulic pump for the feed decided to let the magic smoke out, now to revamp that design.
  • Sad
Reactions: jblnut
Pops got a bunch of manure hauled so Miss Middle Child and I worked it in.
This rig sucks 15-17gal/hr of that $5.70/gal cherry red Dino juice so we’re only working up what gets manure and the really heavy clay ground.
I spent a while getting another dozen totes ready to hold firewood.
A new 24” .050 3/8” bar showed up that’ll live on my soon to arrive ported 462R. Pretty stoked about that thing.
Saturday Joe B is gonna come and stick a Boiler Commander on my boiler and I’ll likely fire it up for the winter.
Reactions: brenndatomu
Boiler Commander is installed. Gonna fire the stove up tomorrow and see how things are going forward. Joe says “Call me!! 320-429-1900”. Every time I’ve text or called he’s responded quickly. He’s got more Commanders ready to go if anyone else wants one.
While Joe was installing the Commander we got to talking about stuff and that lead to building a thing to cover the shaker grates in the stove. Before the thing ……
The thing. It’s a piece of 1/4” plate bent to fit over the grates. It should direct air flow to the sides of the stove instead of blasting it through the center the ash bed and blaring holes in it. It should also help the wood burn more completely as the O2 will come in from the sides and not under the wood pile so I can load it to the tippy top each day instead of half loads.
Holy moly it fit the first time !! Gonna fire it up soon and see how it and the Commander do this season.
The only thing bad about any of this is two mods at once...now you won't know what was responsible for what. BTDT.
That grate cover should help though...that was a popular mod with the Englander 28-3500 wood furnace owners. The oem floor was firebrick with ~1" wide gaps...guys would cut a heavy steel plate to overlay and neck the slots down to 3/8-1/2" so they'd "hold coals" better...from reports it worked pretty well.
Reactions: jblnut
I agree but both things will produce the positive results so I'm okay with it.
The grate cover should direct the air around the outside and the Boiler Commander should take care of the rest.
good luck Mike, I didn't get you any pictures yesterday, didn't feel the best, had to use my buddies JD skidloader to get the polar in the garage, it was basically to heavy for the machine but we kinda skidded it in, the lifting eye literally raked the floor joist for the attic! you can sorta see it in my avatar, bear in mind though that the garage has 6 concrete sides above the floor that the dirt is partially covering in the picture.
