I just finally, after wanting one for years picked up a moisture meter from Lowes and immediately tried it out with surprising results.  My oldest wood was cut this spring, early.  The first stuff I cut and spilt I've moved into the basement and it's a combo of sassafras, maple, and grey birch.  This all measured between 9 and 13 % moisture content which I was happy about.  Next I went to the wood shed and measured the stuff I'll be burning by late December through early Feb, this is mixed beech, oak, white birch, and a little sassafras mixed in...I split this stuff and stacked it immediately in the wood shed to dry with the heat and breeze and it all measured no higher than 14%.  I went down the the stacks from older to newer selecting a few test pieces to split and test with the meter and everything I have is below 20...I think the highest I got was an 18 on the stuff I don't plan to burn until spring. Finally, I got to a stack that was two year old oak logs that was just cut into sections and split...I consider this too wet to burn and am planning on burning it next year as long as my other stuff holds out.  For the heck of it I tested a few of these pieces and they were at 25 to 26 % moisture.  I thought they'd be a higher number and am thinking by spring they could very well be burnable.  I'm kinda surprised with the readings I'm getting but I'll take it.  I always worried that my wood wasn't truly ready yet but it seems it is.  I do split on the small side so that could help them dry out quicker.  Anyway, this meter is pretty fun and I'm going to use it to experiment with different drying methods to see which one is most effective.  Again, my method is to split a piece in 2 and immediately measure the fresh split side by sticking the two probes into the grain of the wood.  Do my findings seem to be in line what others find with wood that's only 7 months down to 3 months old?
