New VC Intrepid Flexburn issues
waltermichener
2
Kansas
After 35 years of happy woodburning, the VC Intrepid Flexburn is my first modern EPA compliant stove, and I am not finding the transition easy. I'd be very grateful for any help with the following issuesl
1) The "2-3 inch bed of embers" we are supposed to maintain completely covers the incoming air vents at the rear sides of the firebox. In the morning, when the stove is cold, those vents are, predictably, blocked with ash and it's not obvious how to get it out without just pushing it farther in. What do I not understand?
2) I constantly wonder if the air-intake lever is doing anything. When I open it, there is no obvious increase in draft. (There is no problem with my draft, as the flames roar up as soon as I crack the ash-drawer door.) When I push the lever closed, I'd expect the flames to subside but they don't.
Thanks in advance!
1) I don't even think about the coal bed when running my Encore, Stovetop temp gauge to start the stove then Auber digital probe after that. I believe they state the coal bed to keep the secondary combustion/Cat hot, digital probe will tell you what and when you need to do things. The vents will self clean (only air coming into the fire box) when you close down the stove dampener and the cat/secondary air control is doing it's thing, at this point you will have the air lever nearly all the way closed and the secondary air control provides air through the small holes. There will be a little ash sitting on the lip below the holes in the morning - I just use a piece of kindling and clear it before getting the fire built back up.
What type of wood are you burning?
2) you should be able to check the flapper in the rear of the stove to see if it is actually closing - some folks report the cable not being routing correctly and it is leaving the flapper open, you should be able to hear a "thud/clank" when the flapper closes. Keep in mind you will not see a huge difference in the flames being cut back with the dampener open, you should see some, but when the dampener is closed you should see the flame slow/retard within a few seconds.
I love my Encore NOW, but is has taken a few years to figure it out.
1) check/replace all factory gaskets (yes on a brand news stove, 3 of my gaskets were issue and the pan was out of level)
2) make sure ash pan is level and sealing properly (I fill the ash pan and never empty it all season, keeps the firebox better insulated which gives better temp swings)
3) get digital Auber thermometer and 2000F probe, this will be what you run the stove off vs the 2-3" coal bed and the analog probe supplied with the stove.
Thanks for your detailed reply! I am reassured about not worrying about the coal bed and about letting the air passages self clean when the damper is closed. Also is nice to know that it has taken you a couple of years to really get to know your stove. You ask what wood I am burning: osage orange. Yes, I know there are warnings about it burning too hot, but it is abundant here and I've been burning it for 30 years. I figure that as long as I'm watching that the stove doesn't over heat, I'm OK.
Regarding whether the flapper is actually closing--there is no thud or clank to be heard, and it is hidden by the rear heat shield. I've tried to remove that heat shield to have a look, but the knob on the air control lever prevents me from taking it off and getting a look at the air aperture. Again thanks for all your advice.
Another question: this model is called a Flexburn, the idea being you can use the catalyzer or not. If I choose not to, do I continue to use the damper in the same way? There is no discussion of this in the owner's manual.
