When it is cold, and especially when wind is blowing, your major heat loss will be your walls. Your inside wall is the outside, no air gap, no spacing.
Soapstone? Never had one,never would, I'm now all pellet, no wood stove. Soapstone, while yes, you gain a little "reserve" as it is cooling down, it also takes more heat and longer to heat it up. Net gain=0.
My place is partial log, smallest one is probably 14", swedish cope, with 2 layers of permachink in all the joints. I live in the mountains. Built my upstairs with 2x6 rough cut, vapor barrier,drywall, 1/2" sheeting on the outside,covered by 3/4" german lap siding,tar paper between them. My upstairs windows are doubled. A window on the outside, the gap because walls are so thick, then window on the inside. The upstairs makes up for the downstairs, in heat retention. Used to heat it from the basement up, with a wood stove, then a pellet. But older now, so put a pellet on the 1st floor,living,kitchen,pantry and mud room, and use about 1/2 the pellets. Basement is dirt, and about 1/2 underground. LP for backup, pilot light, because of power outages. So ya,I know a bit about logs and cold weather. It sucks to see frost on the inside.
