Newer Guy Lots of Questions
4wydnr
15
N. IL
Hello I currently have a magnum corn\pellet furnace that I'm very disappointed in. It can barely keep the house at 61 degrees on a 35 degree day with no wind. I've fiddled around and tried all sorts of different variable and nothing changes plus that corn costs money even for a farmer like myself. Anyhow enough about that, my parents have a wood furnace in their basement and a similar sized house that they can keep a nice 76 no matter what the outside temp is. I know there are variations in insulation and house layout and that is fine.
So there is a little back story now to the questions. For next winter I want to put in a wood furnace to heat the house with. I have a brick chimney that goes up through the two stories of the house and is cut off in the attic. I'm wondering what my best option ( read safe and inexpensive) is. Can I put a liner in the chimney and connect it to some double wall pipe and then through the roof? Or would I be better off to run the exhaust outside and double wall all the way up the side of the house?
4wydnr said:
... For next winter I want to put in a wood furnace to heat the house with. I have a brick chimney that goes up through the two stories of the house and is cut off in the attic. I'm wondering what my best option ( read safe and inexpensive) is. Can I put a liner in the chimney and connect it to some double wall pipe and then through the roof? Or would I be better off to run the exhaust outside and double wall all the way up the side of the house?
Ok,
All about chimneys
(broken link removed to http://www.woodheat.org/chimneys/chimneys.htm)
(broken link removed to http://www.epa.gov/woodstoves/fireplaces.html)
http://www.rumford.com/classicflyerplan.html
Now see pages #8-9 at
(broken link removed to http://www.woodstove.com/manuals/Key-Pal_Manuals/Installation) K-P1-10.pdf
Next go to
(broken link removed to http://www.woodstove.com/pages/wood_stove_Install.html)
Scroll down to B. Existing Fireplace Check out A. B. C.
That should bring you up to speed to decide which way is best for your operation.
Good luck with the heater.
