clemsonfor
. Believe it or not steel does not burn or vaporize that easily as we were led to believe on 9-11. You need extreme temperatures to warp and or melt 1/4" plate steel and/or cast iron.
. After 5 months this installed and very thin bottom piece of flashing still has not burned through and this fact still makes me scratch my head repeatedly over 9-11.
So I hope this was helpful and it eases some concerns you have. Fire is not that dangerous after all if you can control its behavior.
The stuff was also in a super hot fire and had jet fuel, or basically kerosene all over everywhere and was way hotter than a tiny wood fire would get?
Do you also think it was an inside job.. bush or trhe CIA planted the explosives and knew about it and then detonated them so that they could kill off thousands more innocent hard working Americans to then help put a downward spiral on the economy??
Wow 5 posts and some good info coming out of here??? 2 pieces of wood to have a wonderful heating fire for 2 hours, and 2" diameter on that??? I must be lied to when they say my CAT stove is 90% efficient? maybe they mean it burns 90% of the wood and I get very little heat...I need to pull my bottom bricks and put in some cast iron pipe, to increase my heat and burn 500% less wood!!
Imagine if those with the blaze king kings pull their brick and load it up with cast pipe, they will really only load the stove once a week
If bricks insulate and keep the heat in to reduce emissions and send smoke up flue, why would the pipe not do a similar thing?
