Every so often I need to burn my stove with as little smoke as possible.
I usually burn softwoods (doug fir, and red alder) in my princess during our long burn season which is about 9 months. The stove and cat are just starting their third season.
On this hearth I previously had a noncat hearthstone that consumed almost 30 cords before I switched to the BK. I tried some pressed wood products that puffed up and some that didn't with the non-cat and wood was better.
The BK is thermostatic and able to regulate the burn rate much better than a non-cat and in an effort to reduce smoke I chose to try burning the ultra dry and clean North idaho energy logs. NIELs. I bought 20 of them for 30$ but the loader said the ends looked scuffed on some so he gave me 30 of them. They are 8# each. Look like a huge pellet. Totally round.
Cold stove with 1/2" of ash on the bottom. I loaded 6 of the logs which is 48# of wood and just barely exceeds a full load of firewood in weight. Yes, I've weighed a load of firewood. Three on the bottom E/W, two above in a V N/S, and then the last one on top E/W. They just barely fit under the firebox top. Lit the whole mess with a chunk of firestarter and a lot of fine kindling. My loose loading was intended to speed up the ignition process and burn smoke free ASAP.
These things are hard to start. After an hour the stove temp and cat temp are as shown. Everything is very slow to warm up but then, almost all of the sudden, things take off and the gasses burst into secondary flamage in the firebox. I reduced the thermostat setting about 30 minutes before bed to a nice low setting and the cat was the only thing glowing and boy was it glowing. Nice and hot. Stove temp near 600.
These things smoke. They smoked a lot during warm up and they smoked continuously during the burn and 12 hours later this morning the stack was still smoking despite a glowing cat at 75% of max temp.
The cat does love the smoke from these things and the stove was running great at 400 stove top, 400 flue temp, and 75% cat temp 12 hours into the burn. At this point the logs had only slightly shrunk.
So the whole point is that I don't want smoke and these things smoke more than cordwood so for that purpose they fail. I'll update the thread with burn time information after the 24 burn that I expect.
