We just started up our new Classic Edge 750 the other day. It is my first OWB and It is hooked directly into our existing oil boiler which had been heating the house prior to our purchase of the 750.  It was installed and is set up so if the fire goes out or if we don't feed it, the oil boiler will kick on when the water temp. drops to 140 degrees.  The oil boiler is suppose to shut off when the water hits 160 degrees and it will continue to do this until the OWB is up and running again.
I am just wondering what to expect when the oil boiler tries to heat 300+ gallons of water that the 750 holds from 140 to 160. Will it run constantly or will it not be so bad?
The name plate on the oil boiler reads the following BTU ratings. Not sure how to decifer it.
DOE 147,000/172,000 BTU
IBR 127,000/150,000 BTU
