I've seen some old houses with interior brick walls for picking up heat from a fireplace.  I've heard of other walls with "river rocks carefully placed in the walls."
So, building on this, would there be any advantage to put raidant heat into a concrete interior wall? Once it heats up it would probably give out heat for a good amount of time. It would also be easier to insulate from the cold ground than a slab.
Any ideas?
Supporting the weight would be the only downside I can think of. BTW this was the problem with the brick wall mentioned above.
Matt
Any ideas?
Matt
