ryanwc
You know there's a country Ecuador, which was named because it's located directly on a longitude line?all longitudes are equators....
My outhouse does not flush.......my toilets flush clockwise.![]()
Maybe try running the stove upside down and see if the burn pattern reverses?Some of you may recall a question I had about the earth's rotation affecting the burning of our stoves. My dealer had stated that just as toilet bowls flush in one direction in the Northern Hemisphere (and the opposite in the Southern), our stoves won't burn evenly depending on which way they're facing. He said, "if it backs up to the south or east" it won't burn evenly. I didn't know what to say to that. ?
So my dealer was once again in my house for another reason and said the same thing when I asked him about my stove not burning wood down one side as quickly as the other.
As you can see in this photo from this morning when I was burning down my coals, the latch side is alive with flames over the coals. The hinge side is black, behind a black glass, seemingly getting no air? I don't get it...
Maybe try running the stove upside down and see if the burn pattern reverses?![]()
i can't remember where i read it but the smoke goes up the pipe in a circular motion. and if the world was flat the water would run off the sides and we would have no ocean's![]()
naw, runs off the sides and is recirculated from a big drip tray. heck of a pumping station though.i can't remember where i read it but the smoke goes up the pipe in a circular motion. and if the world was flat the water would run off the sides and we would have no ocean's![]()
I always want to tell that guy and everyone who gives him money that a plane ticket is like $300, and passenger jets go way higher than steam powered Wil E. Coyote rockets. They have windows, too.
I have not done so because I am entertained by the Will E. Coyote steam powered rockets.![]()
Does he have an explanation for ships disappearing from waterline up, as they sail away from him, and reappearing masthead down as they return?
![[Hearth.com] One side burning due to earth's rotation? [Hearth.com] One side burning due to earth's rotation?](https://www.hearth.com/talk/data/attachments/225/225583-38ce3da1b42361cd28db75baf15f196b.jpg?hash=mnZPS-g73W)
The Coriolis effect is a real effect, but only should be considered a force in a rotational frame of reference, which is indeed what we experience on earth. But as Ashful said, the effect is miniscule on small scales such as bathtubs, stoves, etc. It must be considered on larger scales such as weather forecasts (horrible math) and how to aim your ICBM missiles, but insignificant in everyday life.The Coriolis effect is real, but is swamped the the myriad of other forces and reactions happening in a wood stove. If it has any bearing on how your stove behaves, it is almost certainly immeasurably small.
