This is like the 4th real day burning. We set fires last weekend and then started up again last night and then today with the blizzard. We've been running the stove around 450-500/550... although we haven't been real successful at "cruising" yet. We are still a bit timid with loading the stove full but are being careful to keep the stove temps out of "creosote" zone. We are learning. Therefore we've had the damper open quite a bit, but today we did a better job of running the fire for a few hours with the damper at half.
Mostly burning very dry wood around 10% but yesterday i got a load of stuff that is 19-22% and we've been mixing that in a little bit. Its not ideal wood so I figured we'd mix it in gingerly with the dry stuff?
I just found a puddle of black stuff under the stove, the size of a small pancake. It was to the rear... sort of under where the pipe is. I tried to get my head under there best I could and nothing is currently dripping. I maybe see some drippy looking cement(?) near a bottom seam, but it looks most likely like it came from the 3" diameter (or so) hole that is at the bottom rear of the stove, behind the heat shield. It was easy to wipe up off the concrete. It was wet. I was scared it would stain so I wiped it up before I took a photo.
What is that? Should I worry?
