Had a piece of plywood 1inch by say 2 1/2 get stuck midway though auger (out of bag). Removed auger to get it out. Since then auger will not run. Feed light doesn't come on. What I have done. Checked to make sure bearing turn freely. Have spare motor both work on bench fine. Cleaned every part of stove, including re-removing auger. Once in a while I can get motor to run for one cycle but that's it. Don't have any ideas except board(don't know how of what to check) and low draft pressure switch (also don't know what to do with it. Ie check if that is issue). It is later serial # model like 2008ish. Has yellow thing inside hopper.
Thanks for help
Thanks for help
