I was thinking the same thing, but the face does not have the vertical face bar on each side of the door opening, where there is a seam from each upper door opening corner running up under the top cover. Unless they made freestanders differently than inserts.2009 would make it an A body.
The freestander may be different. Our 2008 Alderlea doesn't have that vertical facebar either.I was thinking the same thing, but the face does not have the vertical face bar on each side of the door opening, where there is a seam from each upper door opening corner running up under the top cover. Unless they made freestanders differently than inserts.
On the inserts, they did away with that separate panel, and went with one pc of facing.
I mentioned to her that we're capable of doing this work ourselves, she seemed "iffy" on that and said she'd have to run that by PE to see if they were fine with us doing the removal and re-installation as apposed to them (being a dealer).
Dealer has now agreed that we are allowed to perform our own removal and re-installation.
However they are stating that PE will only allow the warranty repair to proceed if we agree to have a draft measurement done after the re-installation.
$250
We've decided to play hard ball at this point as it seems every response we get from this dealer is another reason for them to charge us money.
So,we went back to them and said we'll agree on a draft measurement however we'd like to do it on the current installation with the expectation of the following results:
A. The system overdrafts - in which case we'd like to know how as we're running an external brick / steel lined chimney, two 90 degree bends to get there and a flue damper. The flue damper is considered PE's choice of control measures to protect against over draft. We already explained to the dealer that with the air intake on "L" and the flue damper closed we can pretty much choke the fire to nothing (indicating adequate control).
Also, if the system, as is, is over drafting, what other measures can be added to control the draft. AND how poorly choked of a fire should we be running to produce what PE considers reasonable (contrary to all other reasonable techniques generally taken as "best practices" in terms of a fire not being so poorly chocked that excessive creosote and exhaust particulate become an issue).
B. The system has proper controls in place to prevent over drafting - in which case then we'd prefer to have a new stove vs a repaired one as there's obviously an issue with the stove that is not going to be solved by welding over the current cracks.
The dealer has yet to produce anything in writing from PE / distributor that a draft measurement is a 100% requirement after re-installation to proceed with warranty.
My brother inlaw has made the same claim with his stove but different dealer. He put his claim in after we did and just picked up his repaired stove today. We're getting a little frustrated but don't feel like we should be forced to pay anyone to have warranty work done, especially considering we've seen nothing from PE themselves, for all we know the claim is in and pending.
We hate this back and forth and are people who don't enjoy conflict, we simply wanted our stove fixed as per the terms of the PE warranty.
This all started with just a baffle and now we can't even use our stove.
Does anyone know if there's an alternate way of making warranty claims other then through a local dealer?
Is there a regional distributor we can get a hold of?
Good luck. Politely, stand your ground.Thanks @begreen maybe while we wait for this dealer / distributor correspondence to work out we'll take a good look at our EBT system as well.
I'd be inclined, like you, to simply seal it up. We appreciate the insight.
EDIT: Distributor is now investigating the warranty claim.
Document the entire process with photos, including the repairs. Load up for bear, even if you end up not needing it.
While you have it out, drop the EBT set up and make sure the flapper is in properly and operational.
I found mine to be dislodged from the factory, and therefore it was never operating properly and was constantly open, feeding the added air to the fire.
I'm more suspect of the way the sides of the air wash plate are welded tight to each side of the opening. If I was still burning my A model, I might consider cutting those end welds loose, or at least cut them loose except for a small spot on each end. I don't suggest that for you as it may bring more warranty issues. Just go with the flow for now, and if the welds fail, press for a new stove, newer body model.
Sorry, I meant to comment on EBT, I've been thinking about since reading some other posts about it. We checked ours out at some point through all this and everything seems to move freely. But given the current state of the stove we haven't had any strong fires to test the actual functionality. With the current setup, we can choke the fire down to near zero with the air intake a low and the flue damper closed up, so I believe we have decent draft control. This all being said, I do agree with a statement you made early in this thread @begreen that with a long chimney stack (which we have, albeit external brick) perhaps there's enough draft to "suck" the flapper open when it shouldn't be. We will likely take your advice and block it off (in a reversible manner). Personally, we'd rather lose the EBT function then have the stove over fired due to a malfunction.If your draft is strong a (reversible) mod to try is taping off the ebt intake with metal tape or a flat magnet to see if that improves controllability of the fire. This made a notable improvement with our stove's older EBT1. AFAIK, it's not necessary with the EBT2 design.
