Sure, if you have wifi access. You can use a Nest or any other type of wifi thermostat setup. Or, if you're always going to be there Friday at 8pm, then you can use a timer to set the stove to start Friday at 4pm.also im thinking if heating just 2 small rooms with radiant heat, or electric heated floors all week instead of 3 days of pellet stove (for the entire cottage) then 2 days of radiant heat in the 2 rooms, would this ultimately be cheaper? If I ran just the radiant heat in the two rooms all week, is there anyway I could start the pellet stove from home so the cottage would be warm when I arrived? or even another system for that matter, wirelessly from home?
that the wife approves...
