Poplar, or Poplar
PapaDave
5,739
Northern MI - in the mitten
I cut down a couple of trees this afternoon to be used as sleepers and posts, and thought they were the same until they hit the ground.
The leaves are different, but the bark looks similar.
Any guesses....sure things.....? [Hearth.com] Poplar, or Poplar[Hearth.com] Poplar, or Poplar
Big tooth and Quaking Aspen
1st is some kind of poplar
2nd is spen.
I agree with nrford. The first is Bigtooth Aspen, as indicated by the large teeth on the edges of the leaves. The second one seems to be Quaking Aspen because although it is clearly an aspen the teeth are so small I can't see them on the screen. They are closely related and I assume the wood is pretty much the same. Around here they sometimes grow together, but Bigtooth is more likely to occur in oak forests while Quaking Aspen is more likely to grow along wood edges, roadsides, etc.
Reactions: ScotO
1st is white poplar
2nd is Quacking (or Trembeling) Aspen
My guess.
TS
Maybe put "HD monitor" on your Xmas list. ==c
You can check the stems. Quaking aspen will have a flat stem that will be perpendicular to the leaf surface. Thats why the seem to rotate in a breeze.
Good info. and much appreciated. I'll check the stems when I go back out today.
It's funny because up here, it seems like everyone just refers to all these variations as Popple.
Reactions: ScotO
Yup. Popple it is Dave.
Reactions: PapaDave
