MountainStoveGuy
Warren said:MSG/Craig...Just curious. What's wrong with a stove sitting in front of a 0 Clearance fireplace? If a full reline dropping into a peice class A that connects to the stove, how is that different than an insert? Also, if the walls around the 0 clearance are done such that they also are fireproof and clearances are observed, what is the problem?
I'm not saying your not right, I'm just wondering what the problem is? How is that much different than a Hearthstone Homestead Hearthmount?
Elk, thanks for stepping in,
Warren, i have the same argument, Why not?? As long as you maintian clearacne, reline the chimney, i dont see a problem with it. The problem, looking at lots of stove manuals the last few days, is that there are only provisions for installing into masonry. So basicly, Stoves arent tested and listed for a ZC install, and ZC's arent listed for a stove install. Off to work i go...
