Hi gang...bought the Avalon Pendleton insert used a year and a half ago for supplemental heating...installed (professionally) in a vintage 1950s "Heatorlator" metal firebox...6 ft flexible stainless pipe from stove meets flue in chimney (rebuilt in the 1950s)...insulated around the original hearth opening on top of the stove- on the sides, less than a quarter of an inch between the stove and the hearth opening is uninsulated and open.
room with the insert is 12'x16', uninsulated walls, one window and exterior door, below- uninsulated crawl space, above- uninsulated attic...(House is 1896 farm homestead Victorian- 1st floor front 3 rooms insulated and over unheated full basement, back 3 rooms- including one with insert- uninsulated and over crawl space).
Last year the stove was a disaster, failed to heat the room it was in much less the back part of the house...bought a blower and the output is better but fails to heat appropriately...the outside temp of the stove ranges from 350 to 450 depending on the wood used...in 25 degree nights the room will reach a maximum of 74 degrees averages around 68 (thermometer at eye level) but fails to heat any of the other rooms...in 15 degree nights (last week) the room reached a maximum of 64 degrees and hovered between 58 and 62 degrees...and the central heating system does kick on as the thermostat is in a different room in the middle of the house, so the room with the stove is getting help from the central heat system.
have no problem starting the stove, draft seems to be good, only slight smoke will enter the room if I open the door too quickly...I am very disappointed- I had visions of walking around in a tee shirt (at least in that room)...I had a friend who is a former engineer come take a look and he seems to be stumped...of course, insulation would be a plus (yet complicated) but the friend said that the room with a 400 degree stove should be toasty without insulation...the heat is going somewhere...any suggestions are greatly appreciated...thanks, micky
