Quadrafire mt vernon conv blower jam
Rich1359 Posted By Rich1359, Jan 4, 2019 at 10:32 PM
  1. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    Well, it's now day two and the convection blower shut down for about 10 seconds and started back up again. First time I have noticed it. I will try to locate a dt thermocouple tomorrow. Thought I had it fixed......
  2. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    Where does the end plug in? I know the one end attaches to the drop tube just not sure of the other.
  3. Ssyko
    Ssyko
    Minister of Fire 2.
    NULL
    Nov 6, 2017
    2,209
    529
    Loc:
    Lorraine NY
    Through the harness eventually ending at the control board. There should be connector at the end of the wires
    Stop hovering to collapse... Click to collapse... Hover to expand... Click to expand...
    kappel15 likes this.
  4. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    So the conv jam came back. I unplugged it , it goes to auto clean and then it shows the top and front front door open and wont start. It is 2 here right now and no other means to heat. Anyway to jump things out? I need help!!
  5. kappel15
    kappel15
    Minister of Fire 2.
    NULL
    Sep 14, 2014
    2,205
    433
    Loc:
    Iowa
    Unplug stove again and plug back in. Pull face off wall control and put back on. If that don't work, unplug stove, turn gray dial to 1. Plug stove back in, wait for it to do an auto-clean, then unplug again, and turn back to 0. Plug back in and see how it goes. If you have any downloaded fuel tables, it will delete them and go back to factory. Let us know. kap
  6. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    So I checked all the wires and could not find anything wrong. I noticed if I opened the front door and the top, and then closed the top, it only showed the front door open. I closed the front door with the top open and then closed the top and it went in to startup mode. It seemed to take forever for the pellets to light (i thought the igniter went out too) and then all of the sudden it started up and has been running for about 45 minutes. I am worried what it will do when it shuts down for auto clean. If it does it again i will do the steps you said Kap
  7. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    Oh, what gray dial?
  8. kappel15
    kappel15
    Minister of Fire 2.
    NULL
    Sep 14, 2014
    2,205
    433
    Loc:
    Iowa
    You may want to check hopper lid an door sensors as they may need to be adjusted for a better connection. The gray dial is on the control board. kap
  9. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    Thanks Kap, it is just shutting down now. Sure hope it starts again, it is -2 outside now.
  10. kappel15
    kappel15
    Minister of Fire 2.
    NULL
    Sep 14, 2014
    2,205
    433
    Loc:
    Iowa
    I would be looking for a back-up heat source too. Can't depend on just a stove.
    bob bare likes this.
  11. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    I agree, already looking at having the propane furnace checked. Hasn't been run in 7 years
  12. kappel15
    kappel15
    Minister of Fire 2.
    NULL
    Sep 14, 2014
    2,205
    433
    Loc:
    Iowa
    So, how did it go? kap
  13. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    Hi Kap, it ran all night and is still going strong!
    bob bare and kappel15 like this.
  14. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    And it just died, conv blower jam error again. I have a new drop tube thermocouple, where does it plug in to?
  15. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    So replaced dt thermo, now both the hopper and front door are reading open. I dont have a gray dial on the control board on the wall.
  16. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    Ok, found the gray dial, switched it to 1 as you said, plugged it back in and read the doors were open and would not auto clean
  17. kappel15
    kappel15
    Minister of Fire 2.
    NULL
    Sep 14, 2014
    2,205
    433
    Loc:
    Iowa
    Ok. Need to get the icons off wall control before auto clean will work. Have you checked that the sensors are close enough together to get signal? Have you traced their wires and checked connections are good? If push comes to shove, those two sensors connect to a wire harness right above the vac switch. You could make a jumper wire to stick in connection,after disconnecting the switches, to bypass those two sensors. Just be sure stove is off, or you don't ground wires out on stove. kap
  18. kappel15
    kappel15
    Minister of Fire 2.
    NULL
    Sep 14, 2014
    2,205
    433
    Loc:
    Iowa
    After checking all connections on conv. fan wire harness and with a new drop tube thermos, if things still act up, I would have to say time for a new conv. fan. kap
  19. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
  20. kappel15
    kappel15
    Minister of Fire 2.
    NULL
    Sep 14, 2014
    2,205
    433
    Loc:
    Iowa
    Sorry, I didn't go back thru all posts. I would check all wire connections if we get this going and the new drop tube thermos doesn't do it. Also sorry I am not helping much, but hard to fix a stove over the computer. kap
  21. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    I checked the wires from the switches, all look good. Seems weird that both of them are malfunctioning.
  22. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    There are two thin black wires from each sensor correct?
  23. kappel15
    kappel15
    Minister of Fire 2.
    NULL
    Sep 14, 2014
    2,205
    433
    Loc:
    Iowa
    Yes and they hook to their wire harness's right above the vac switch. Did you pull those connectors apart and put back together and trace to control board and pull that connection off and put back on, just trying to reseat things for better connection.. Also check sensors to make sure each half is close enough to each other? If this fails, then pull connections apart above wire harness and make jumper wire to bypass these switches, to get stove going. kap
  24. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    Unplugged and plugged everything in, didn't do it. I wonder if the main board is bad? It ran great for the last 24 hours, conv motor jammed error and now this.
  25. Rich1359
    Rich1359
    New Member 2.
    NULL
    Jan 4, 2019
    58
    6
    Loc:
    Western ny
    Can I just cut the wires and wire nut the two together?
