SmokeyTheBear said:No to the last of the items, no need to take the stove out.
I still have plenty of questions since you are likely still close to the cut off point on that exhaust system.
Does that stove have two augers, and a shallow sloping fire pot that should allow the ash to be pushed out of the pot by the feed of new pellets from the back of the fire pot?
Is it the burning pellets that are in danger of falling out of the pot or will the ash be what falls out?
My unit is a drop feed and the ash can only leave the pot via being ejected by air when disturbed by incoming pellets or by the air flow through the firepot.
The other thing is since the stove has an OAK does the outside end of the OAK have any guard that covers it?
So my pipe isnt all that long now. I have the T and one 90 and 6' vert pipe and then 3' horizontal and the cap on the end. Is that still too much?
The stove has one auger. from the bin to a chute that gravity drops into the burn pot. the best way i can describe this is that the pellets just pile up and like ... half burn ... and then fill the entire pot overflowing both on and half on fire into the sides of the stove etc.
the OAK has a deflector plate for protection.
I had my girl shut it off and clean it earlier and now i am running a second test with the new pipe length as well as the gasket and plate in there. So I am going to call Englander in the meantime and update them a bit and see what they say and if they have any other ideas etc.
Nice. At least we know what the problem is. Now its just a where/with what. I will snake the OAK from the back of the stove to the pot like you were suggesting and see what happens. I have a multimeter but no idea what to check with it.
