Regency now wants $130 for just the probe and another $340 for the digital monitor. What are my other options that will install into the hole in the stove for the cat probe? I want a probe that will attach to the Auber AT100.
Do I need the 6" probe or 10"? The Regency manual says to remove a 7/16" bolt and put the probe through the bolt hole. Since the auber probe is only 4mm O.D. (1/8") what do I do with the gap in the hole?
7/16 is probably the bolt head size. What is the diameter of the bolt?
I don't know anything about your stove. With my VC the bolt hole for the probe is only in the cast not the refractory box as well. I had to take a drill bit and by hand gently drill a hole the same size as my probe in the refractory box.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
