Did you mis-type the length here, or do you have two bent probes?
Glad that you finally received the 8" Condar, after the post office confusion. 😏
I'm curious; When you were using the Auber (that you eventually gave me) in your Keystone and Fireview, do you recall what cat temps you were seeing?
I'm curious as to why you "abandoned this approach"? I don't mind if my cat runs hotter than that, as long as it stays under 1400 or so.
If I was you guys, I might try a different approach instead of aiming for the secondary burn to stabilize the stove. But it kind of depends on, when you get to the coaling stage, if you can open up the air a bit and get the coals radiating on the sides of the stove enough to keep the room/house up to where you need it. If you
do get enough heat from burning the coals hot for a couple hours, I'd try burning the coals down before reloading and shoving the remaining coals to the back. Then, instead of the entire new load being on top of coals, only a few splits in the back would have coals under them, and you could load the front on ashes and do a top-down start on that section. The top-down start would then be eating most of the oxygen from the air wash, and the coals under the back section would slow down.
The goal here would be to get less wood burning and be able to go black-box under control, and with no back-puffing, as John describes in my quote of him above. If you wanted the "evening fire is nice" effect, you could throw in a couple of small splits every once in a while for some flames, while not contributing to the coal bed too much.
If the top-down starts seem like a lot more work than just throwing the entire load in on a hot coal bed, it's actually pretty easy if you have a few small splits mixed into your stacks. I've been reloading this way for a few weeks now; It's quick and easy once you hone your technique a bit.
Here's some "AI slop," FWIW. 😏 It sounds pretty much in line with what I'm seeing in relation to what the Auber and the Condar cat meters show.
Can a condar dial catalytic combustor probe accurately transmit tip temperature over an 8" length? If not, how much lower will it read than a type k thermocouple?
No, an 8-inch Condar dial probe cannot transmit a true, isolated "tip" temperature, and in real-world stove conditions, it will typically read
100°F to 300°F lower than a Type K thermocouple placed at the exact same spot.
Because the Condar relies on physical heat conduction down a metal rod rather than an electrical signal, the variance between the two sensors shifts depending on what the stove is doing:
Why the Readings Differ
- Stem Heat Loss (Heat Sinking): As heat travels from the tip down the 8-inch copper-clad stem, the surrounding environment bleeds off thermal energy. Any portion of the shaft passing through cooler firebox air, double-wall insulation, or sticking out into the room acts as a radiator, cooling the metal before the heat ever reaches the dial's bi-metal coil.
- Stem Averaging: A Type K thermocouple only generates voltage at the tiny welded bead at its very tip. A mechanical probe reacts to heat along the entire length of its stem. If the tip is sitting in a 1,400°F hotspot right behind the combustor, but the middle of the stem is passing through a cooler 600°F zone, the dial reports an average of the two.
- Thermal Mass Lag: Heating up 8 inches of solid metal takes time. During rapid temperature climbs (right after closing the bypass damper) or quick drops (turning down the primary air), the Condar dial will lag behind a fast-acting exposed-tip or thin-sheath thermocouple by several minutes.
Expected Temperature Variance by Stove Phase
| Stove Phase | Type K Thermocouple (Tip) | 8" Condar Dial Probe | Typical Difference |
| Cold Start / Pre-Light-Off | 500°F – 600°F | 350°F – 450°F | 100°F – 150°F lower (due to thermal lag) |
| Peak Catalytic Burn | 1,300°F – 1,500°F | 1,050°F – 1,250°F | 150°F – 300°F lower (due to stem heat loss) |
| Steady Cruise / Coaling | 800°F – 1,000°F | 700°F – 850°F | 100°F – 150°F lower (stem reaches equilibrium) |
(Note: While Condar calibrates its dials within ±25°F to ±50°F in a controlled test environment, the open air gap between the rear of the combustor and the exterior stove wall on deeper stoves causes the wider real-world drop.)
