Oregon aloha
I thought all EPA stoves have a 15' min. height because that is the EPA testing height. Is this not true?
Sorry, maybe this was already covered elsewhere, but I'm assuming you have a masonry chimney with SS liner? Is it insulated? That would add some draft if it was.
As to one of your original questions, how to extend your chimney height, again, assuming masonry chimney with a SS liner. They make a top plate that adapts from flex liner to class A pipe. I know I have seen a link to one here somewhere before, maybe someone else can put their finger on it more quickly than I.
I have no experience with those draft inducer fans, but to me, that looks like a real PITA on a wood burner chimney...
Lemme see if I can find a link for ya...EDIT, here's one example
(broken link removed)
The Keystone manual says 14' but that's with a 7" flue. I'm running 6" at 17'....drafts great.I thought all EPA stoves have a 15' min. height because that is the EPA testing height. Is this not true?
Yeah, I think that's just a suggested minimum, and probably a good rule of thumb, but mine is only 13' and drafts okay (not great, but okay). Some stoves seem to "breathe" better than others.The Keystone manual says 14' but that's with a 7" flue. I'm running 6" at 17'....drafts great.
The Hearthstone Manchester says 10'....from the floor!![]()
Your chimney may be the problem, Have you looked into the house being in a negative pressure? Exhaust fans, combustion air, dryer. Try opening a window when you open the door to the stove. Also why would you have smoke at all when reloading a burnt down fire? Is your wood actually dry?
What type of stove? I get smoke spillage each and every time I open the door to my quad. No matter what I do.
25 feet of flex on an interior chimney. Some stoves like putting a little smoke in the room I think
I believe the math is right. I've read other sources that confirm that kind of relationship. So if you go ahead and add 3 ft, you probably will get about 25% more draft which more than likely will solve your problem. Every additional increase in height, though, will have a lesser affect.Here's my version of the math: 12 ft chimney + 3 ft (25%) increases draft by 25%. Is this correct?
