I have a heatilator t4200 that can burn wood as well as a gas log. It currently has a gas log that I want to remove and install a wood burning insert (I have no masonry). I have a few questions and would appreciate any hep/comments/suggestions as I know very little about this topic, other than what I have read here.
1. When the gas gas log is removed is it ok just to weld up where the knockout went, is it necessary?
2. For the liner, do I just need to run magnaflex up the existing 8" flue pipe and hook it direct to the insert?
3. If the wood burning insert fits in the existing opening can I use it, or are there different inserts made for masonry and pre-fab boxes like mine?
Thanks for your input, it is much appreciated.
Bill
Bill
![[Hearth.com] remove gas log, plug hole and add liner and insert, is that all [Hearth.com] remove gas log, plug hole and add liner and insert, is that all](https://www.hearth.com/talk/data/attachments/126/126232-2e9739abbf38a2f54d8aaf785f98347e.jpg?hash=eUErxe6KYN)
![[Hearth.com] remove gas log, plug hole and add liner and insert, is that all [Hearth.com] remove gas log, plug hole and add liner and insert, is that all](https://www.hearth.com/talk/data/attachments/126/126242-6c8ac7f0ece9c871c92972609128fb5b.jpg?hash=Phozy4bkLz)
