First post for me. Buying a house in North Idaho and it has a wood stove in the living room as backup for the electric baseboard. I hope to replace it with an oil stove that looks good, puts out plenty of heat to help lower the electric usage, can get fresh air from underneath and vent through the existing stove pipe.
My crawlspace has good venting and should be adequate to draw fresh air from. I will put a tank on a stand behind the garage and plumb the supply line through the crawlspace as well.
Does this sound like a good plan?
Does this type of oil stove exist?
Can a Napoleon stove be hooked up like this?
Should I be looking at propane instead?
Can propane be vented out the stack and still be efficient? Direct vent is not an option as the wall behind the stove is the attached garage.
2 Main concerns: No woodpile in the living room and I would like to use the vent and not have a hole patched in the ceiling.
Here's a picture.
Thanks for any tips.
Clyde
Here's a picture.
Clyde
