Hi there,
I need some help. My wife and I bought a house back in May which had a wood stove. The insurance company did an initial inspection and ending up dropping us because we had the wood stove and no papers on it (installation/inspection?). We ended up selling it to the guy who was cutting down some trees for us for $75, I know I'm an idiot. After we got rid of the stove we got another policy with the same insurance company, which ended up dropping us for not having a railing on our front steps. So we decided to go with a new company who hasn't given us nearly the same amount of trouble.
On to the point... We have a concrete slab in the basement, and a 6 inch diameter hole in the wall to the chimney that was there for the wood stove. We have a propane boiler, but it seems expensive to run and we really don't like the company that is in our area which delivers the propane, so we have been looking into alternative heating solutions. We did some research into pellet stoves and getting another wood stove. I like each for different reasons. Mind you the list above is purely what I think I understand from research online and visiting a local stove shop.
Pellet stove Pros:
* Fuel comes in easy to handle bags
* Seems cleaner
* Less danger, maybe?
* Lighter
Wood stoves Pros:
* Lots of people sell firewood
* Stoves seem to be cheaper, only slightly though
* No electricity needed, can use in case of power outage
* Minimal installation ( drop it on the slab and connect some piping )
Pellet stove Cons:
* Installation cost / labor (running electricity, buying + installing adapters + fresh air in...)
* needs electricity to run
* could be noisy?
Wood stove cons:
* Heavier
* More dangerous
* More frequent chimney sweeping?
So my questions to you:
Are there any good resources online to connect a pellet stove to a chimney that had a wood stove previously hooked up to it?
Is the installation of a pellet stove has hard as I am thinking?
Should I consider hiring someone to install it?
Would I be able to contract someone to install a stove I bought from home depot?
Are wood stoves as dangerous and pellet stoves as safe as people say?
If you can answer any of these questions I would appreciate it. I'm starting to go crazy reading stuff online!
Thanks,
Mike
Pellet stove Pros:
* Seems cleaner
* Lighter
Wood stoves Pros:
Pellet stove Cons:
* could be noisy?
Wood stove cons:
* Heavier
* More dangerous
Thanks,
Mike
