Hi All,
I've been enjoying the forum for a while now and finally decided to ask for help on my own fireplace. The previous owner cut the top out of the Thulman L36 "insert" to put a 'T' on the pipe and put a stove in front of the hearth. The hearth is on an outside wall that has now been enclosed by a garage and is stucco over concrete block. The stone around the inset is about 6' thick.
I'd like to replace the insert with an efficient unit that can be opened up to enjoy the fire and more importantly closed to heat the house. It would also be a plus if the heat output can be regulated. My house is 1900 sqft and heated with propane so it gets a bit expensive when you have a winter like this one.
I'm trying to decide whether I should open up the hearth or go through the outside wall to replace the unit. I think I found the stones that were pulled out where the pipe is stick out through the hearth. Any input on pros and cons would be appreciated.
Choosing the replacement unit is the most important consideration in my mind. I don't know anything about how they are installed and whether that may factor in on installing from the front or the back.
Thanks in advance for your input,
Larry
![[Hearth.com] Replacing Destroyed Thulman Unit [Hearth.com] Replacing Destroyed Thulman Unit](/talk/proxy.php?image=http%3A%2F%2Fi52.photobucket.com%2Falbums%2Fg17%2Fdevopro%2FFireplace%2FFireplace3_zps83b3954c.jpg&hash=a5485a8048447d68a9ca8ccbae74cc99)
![[Hearth.com] Replacing Destroyed Thulman Unit [Hearth.com] Replacing Destroyed Thulman Unit](/talk/proxy.php?image=http%3A%2F%2Fi52.photobucket.com%2Falbums%2Fg17%2Fdevopro%2FFireplace%2FFireplace2_zpsabfcb2cf.jpg&hash=8e17a81a9774d943128b1c790c57f307)
Larry
