I just picked up a 1/2 face cord of black locust for free. I know you can burn ash right away......but how long do I have to let black locust season???
NordicSplitter said:I just picked up a 1/2 face cord of black locust for free. I know you can burn ash right away......but how long do I have to let black locust season???
Backwoods Savage said:NordicSplitter said:I just picked up a 1/2 face cord of black locust for free. I know you can burn ash right away......but how long do I have to let black locust season???
Nordic, while it is partially true that you can burn ash right away you will find it is much, much better to let it season at least 6 months and better a year. Even better yet is 2, 3 or 4 years!
One winter many moons ago we were caught unprepared (due to an injury) and I actually had to buy wood. It was all white ash thankfully, because it had just been cut and split with no time for drying. Yes, we burned it that winter and no, we did not freeze. However, we burned a lot more wood than normal and we also cleaned our chimney more often. We got through that winter but I'd hate to have to do that again.
Ash is low moisture (relatively) when it is cut but still over 30% moisture and wood should be 20% or less. We've been burning ash that has been split and stacked for up to 8 years. Next winter we'll burn all ash that was cut during the winter of 2008-2009. It was split in the spring of 2009 and stacked immediately following the splitting. It will burn nicely and so will yours if you give it enough time to dry.
SolarAndWood said:Black Locust is go to January wood. Unless you have a lot of the good stuff, I would split it big, set it aside and give it two years.
Battenkiller said:Wood stores water in two ways:
Free water - Like the water in a soaked sponge, it can actually be squeezed out with sufficient pressure. It is not chemically bound to the wood fibers, so it evaporates easily with little added energy. When it is gone, almost all species of wood will be at about 28% MC and will not even have begun to shrink yet, so it will be mostly crack-free. Below is a photo from "Understanding Wood", showing how much water can be squeezed from a small block of red pine sapwood (about 135% MC). Wonder why it won't burn?
Bound water - This is like the water that remains in a sponge after you have wrung it as hard as you can. Still pretty damp, eh? This water is a whole lot harder to remove, requiring more energy to break the hygroscopic bonds it forms with the wood fibers. This water has to migrate through the split by diffusion, and the denser the wood, the slower the diffusion rate.
So...
Locust is known to be a very low MC wood when green, but it ain't close to seasoned dry. Like ash, it has very little free water, but the locust fibers hold onto the 28% of bound water for a long time because locust is so dense. Bottom line is that locust may burn now, but will burn so much better in a year. I don't think it needs two, but locust will last 30 years in a stack and still be fine, so it a good one to lay down for the future.
For example, last year I found an old barbed-wire fence with locust posts at the perimeter of the property. I'd guess they were older than this house, which is about 60 years old. The posts broke easily at ground level, but I yanked the wire off and burned those old posts one cold February night and they were still good. Although the outsides were punked up, the inside still had usable firewood after all those years.
smokinjay said:I can say this. I had a stack fall over that was cut in Feb. Fresh cut. Guess where it went.......lol Burned far better than fresh cut ash (Even Blue flame).... I refuse to re-stack it.
krex1010 said:Btw, has the 'kill relaxed to where the trout are cooperating?
