Yes,when they burn 5 tons and forget to clean the fines box.does anyone with a Harman free standing have any auger problems with fines?
not a problem but,Yes,when they burn 5 tons and forget to clean the fines box.![]()
all softies out here,i ignore the fines box,hit it once a yearnot a problem but,
I was very surprised when i went to clean the fines box last week..
been burning ezblaze softwoods which are very dusty but hardly any fines in the box.
say that because with hardwoods i always have lots of fines and broken up little pieces of pellets in that area..
You got me here,what is a "manual windrowing machine?" thanksMy stove burns everything also, but my first year I was concerned after reading of others having problems. Saw a lot of solutions from using a modified gutter with hardware cloth in the bottom (hole cut out of gutter) so the fines would fall out.
Vacuum devices. If you try this route make sure you have a hole in the uptake for makeup air or you may just smash the pellets worse, I know, I tried this method. One season I decided to mix 2/3 corn 1/3 pellets when corn price was high. Even with my cornvac system it would destroy the pellets if I didn't throttle the vac by letting more air in.
Or if you are lucky and can find an old manual winnowing machine they seemed to work pretty good. You might find one cheap as the have little practical value, but they might be expensive as they are also considered a collectable by some.
yes,i know windrowing,but think that you are thinking of a separator,that was used inside a barn,hand or belt run?windrowing is transferring the product into a row,not dividing it.Winnow, winnowing. It's how they used to separate the grain from the chaff, they were first used as far back as the ancient Egyptians.
You can use the natural wind currents, a bellow, or in modern times a fan driven winnower.
Think of it as a cleaner using positive pressure instead of how we do the same thing today with a negative (vacuum) pressure.
https://en.wikipedia.org/wiki/Winnowingyes,i know windrowing,but think that you are thinking of a separator,that was used inside a barn,hand or belt run?windrowing is transferring the product into a row,not dividing it.
Winnoning vs windrowing,my mistake!lol thank you,i think the old hand run machines were seperators.Gret,have a great eveninghttps://en.wikipedia.org/wiki/Winnowing
Maybe people have different names for it, but winnowing is the name I learned.![]()
No problem. I remember those also, I had to actually think for a few minutes (more like 20) to remember the name "winnowing" before I posted. It was like I had a brain stutter. w,w,wi, win...then it hit me. Weird as it puts me back in time to certain things, the smells, bright day, stuff that I hadn't thought about in years.Winnoning vs windrowing,my mistake!lol thank you,i think the old hand run machines were seperators.Gret,have a great evening
