I got some plastic to top cover. I know it will take longer to dry, with the dimensions and that doesn't matter, but am I helping or hurting with top covering. It's going to rain later, and I was going to go out there now, in the heat.
That's kind of an understatement dont you think, in a few years he might have rot in the middle even if he top covers it.Top cover that wood and it will be fine in a couple of years. But you do have it stacked really tight, so it's gonna take longer than double or single rows...
that's kinda funny, Sparky.......I've been doing it that way for YEARS and never had a single bit of rot.....as long as you only top cover it, and give it a few years to season, it ain't gonna rot.That's kind of an understatement dont you think, in a few years he might have rot in the middle even if he top covers it.
So you stack 10 rows tight and it dries in the middle in 3 years with no problems, just cant see where the moisture is gonna go.that's kinda funny, Sparky.......I've been doing it that way for YEARS and never had a single bit of rot.....as long as you only top cover it, and give it a few years to season, it ain't gonna rot.
HOWEVER, I noticed I the picture that he doesn't have the wood off of the ground (with skids or timbers), now THAT could lead to rotting. Air needs to be able to get under that stack.......direct ground contact is a no-no......
Mine is 8 rows wide (12'), 5' high and 62' long.......top covered on its third year, and is bone dry when its time to burn it.So you stack 10 rows tight and it dries in the middle in 3 years with no problems, just cant see where the moisture is gonna go.
![[Hearth.com] Should I Cover The Cube? [Hearth.com] Should I Cover The Cube?](https://www.hearth.com/talk/data/attachments/106/106594-18b433151f8d8ce836e526dda3012291.jpg?hash=wa0bIwSdx0)
It definitely would, you gonna volunteer to help?Wouldn't putting a 1 foot row in between every three stacks help with circulation?
