Shoulder Season - Early Morning Dew cause Pellet Stove FOO !!
Don2222
9,259
Salem NH
Hello
Does anyone have any trouble with early morning damp air clumping up their burn pots??
Last Sunday morning when I awoke bright and early at 9 AM. LOL
Checked the stove and there was alot of black soot on widow and back fire brick.
Yes, I know that can indicate not enough air for the burn but the air damper was fine the night before and the fire was burning fine!
The burn pot was chock full of clumped ash and the there was a lazy flame and some unburned wood pellets!!
See 3rd pic
Since many of the Travis stoves have a square hole in the fresh air plenum at the bottom of the stove, (see 2nd pic) I closed down the OAK damper (See 1st pic) to cut down on the outside dampish air.
This way, more dry heated air is used for burning.
So the last two mornings when I awoke the stove has been burning fine!
Has anyone else seen this??
  • [Hearth.com] Shoulder Season - Early Morning Dew cause Pellet Stove FOO !!
Looks like you are sucking in crud through your OAK, not good, you want air not crud.
What does the outside area around the OAK inlet look like?
Looks like a little dust in the OAK plenum. That should not cause the clumped ash.
I had to stick the camera way inside the back to take the pic so I do not normally see that! I can clean that easily.
The outside is fine.
Now, you have to find out how it got there.
I don't have any trouble with my sealed system so other than to point out the stuff that shouldn't be where it is I'll be of little help.
Hi Smokey
It was just room dust from the inside of the stove. I just removed the room blower and vacuumed it all out.
See pic
I just know that the clumpd ash happens when there is moisture in the air outside and now that I closed down the OAK some it seems much better.
So I will keep testing but that may be the answer.
Do not use as much outside air in the sholder seasons for this Avalon Astoria stove!
