Hi,
First time poster, and also first-time homeowner (...if I had only known!)
Anyways -- I have a dual-flue chimney that supports an upstairs fireplace, as well as a basement wood stove. Facing the chimney indoors, the upstairs fireplace is the right flue, and the basement stove is the left flue (see pics for context, which show my one-night temporary fix to block off the downdraft with aluminum tape...no more fires until I properly address the issue!).
Having looked both upward and downward, I'm 95% certain that each is independent of the other the length of the chimney, and for what it's worth, the basement is insulated.
I've come to discover that when I have a fire upstairs, smoke is going up that flue and down the other, causing the basement wood stove to emit smoke. I somewhat understand this is because there's a negative draw down to the basement, and that the stove flue stoppers and damper aren't fully sealing. I hope to fix that by to the best of my ability by disassembling the stove-to-chimney flue pipe and ensure that the inner damper can rotate to full-close, and to also redo fire ropes on flue collar & stove doors. I'm not sure if that will fix the issue, or if I there are other forces I should consider?
Could someone please speculate on the dynamics of my current issue / setup? And also give some council / guidance on how to best address?
Any council / guidance, preferably qualified
, would be MUCH appreciated!
- New Home Owner (aka, Kevin)
, would be MUCH appreciated!- New Home Owner (aka, Kevin)
