Smokey smell in the house
PapaDave
5,739
Northern MI - in the mitten
Last night, I noticed a smoke smell in the house after getting the stove set for a decent burn.
Went wandering around the house a few times trying to figure out where I may have missed sealing things up.
Finally mentioned the smell to my lovely wife. She said she had opened the stove door to throw something in there and it was from that because she noticed some smoke.>>
I had the air all the way down, and the pipe damper closed quite a bit, and ....yep, you guessed it....she didn't open either when she opened the door.
It's the same thing she does when she adds wood (which happens so infrequently it doesn't occur to me she might).
Just venting a bit. hehehe
The same exact thing happened to me the other day. The problem is I have very little sense of smell, and so I get paranoid that the house could be full of smoke without me noticing :)
The downdraft Resolute Acclaim sure gives a face full of smoke if you forget to open bypass. The old Kent Tile Fire (1986) has a neat feature - the door is latched and won't open unless you pull out the bypass rod.
I have a bad habit of doing the same thing before i open the door and get a face full of smoke.
This is why I am a big fan of KISS stoves.
