I've had a plow on a small riding mower.
Takes a while. Anything deep and you're taking a long while.
Not so sure the transmissions are built to take too much aggressive pushing.
Snapper 824 snowblower. Actually pretty quick.
If I want the asphalt showing I adjust the feet.
I have a gravel driveway, a asphalt driveway and a greystone driveway to do, 2 fairly long - about 20 car lengths long. I keep it up an inch so I don't throw stones and greystone.
The asphalt drive faces south, the sun finishes what the snow thrower didn't get. Usually gets pretty close to the surface, even adjusted up an inch.
If the snow is deeper than the auger face it gets slow going.
The shute used to jam when the paint was shiny new, I'd spray it with a silicon spray. Now that the paint is dull it doesn't stick. Go figure.
I have a JD 2520 with a front end loader. Great for the deep stuff. Great for the heavy stuff at the end of the drives from the street plows. Easy to make a mess of the lawn. I'd rather use the snowblower although the tractor is more fun. Don't hit the garage door.
