I pulled the pin and just bought a small wood/coal burning cook stove from Sopka. http://newwoodstoves.net/index.php/product/royal-720 This will serve to keep my small basement room from freezing in really cold weather when I'm running my pellet stoves and there's not heated air being blown down there. Plus it will be my cooking source for emergencies and AHBL Day.
I know at first glance this should go over to the wood burner forum; however, the owner told me that he will shortly be introducing a new pellet stove from Europe that will require no electricity, which is one reason I got the little wood burner. A back up for the back ups.
His cook stoves are made in Serbia, his home country, but I'm not sure where this new pellet stove will be made.
As he described it, the stove would be gravity fed. Many coal radiant heat stoves are fed this way if not stokers or hand fed. The Franco Belge I had was fed from a sealed hopper over the burning coal bed. As the coal burned down, fresh coal ran out of the hopper and kept the coal bed height constant. Since the hopper was sealed, no oxygen could get up there to ignite the coal. Worked great. I don't see any reason a pellet stove of similar construction wouldn't work. The big difference obviously would be that it would go from a blower style convection stove to a radiant heat type, which would require greater clearances probably.
His cook stoves are made in Serbia, his home country, but I'm not sure where this new pellet stove will be made.As he described it, the stove would be gravity fed. Many coal radiant heat stoves are fed this way if not stokers or hand fed. The Franco Belge I had was fed from a sealed hopper over the burning coal bed. As the coal burned down, fresh coal ran out of the hopper and kept the coal bed height constant. Since the hopper was sealed, no oxygen could get up there to ignite the coal. Worked great. I don't see any reason a pellet stove of similar construction wouldn't work. The big difference obviously would be that it would go from a blower style convection stove to a radiant heat type, which would require greater clearances probably.
