So I've purchased a VC Encore (non-cat) that I'm waiting on installation for, and I've got a couple questions:
- VC says don't run this stove with the doors open with firescreen unless you're running the 8" pipe. Since they don't think I can't run an 8" pipe (hearth installation, replacing a very old VC Resolute) what they plan to do is reduce to 6", which VC says is fine, and then run 25' of 6" pipe all the way up the chimney. They say with this setup, I'm assuming because it will promote a good draft, that I can run with the doors open should I wish to.
- second question: it's been a million years since I've run a stove, and back when I was a kid I was helping my father run coal in the Resolute when they made a coal insert for it. My question is how should I run my break in fires? VC just says keep temp under 500F, but beyond that, is there anything I need to worry about?
Any random pointer appreciated!
Get it hot before you play with the closing the bypass damper.
